Group: DynoMotion Message: 1772 From: frank_19_88 Date: 9/5/2011
Subject: PTT or TTL (Analogue or digital)
Hi Tk,
At the moment i am working on a maho 300c milling machine
And i want to buy a new lineaire encoder:
http://www.renishaw.nl/media/pdf/en/9abe665f4cf84acba38390d354a391f4.pdf
At page 14 i can choice PTT or TTL signals, witch one is the best choice? (Analogue or digital)
Which settings do need for my Kanalog kard?
And what is my "receiver clock frequency(MHz)"?
Thank you very match,
Frank
Group: DynoMotion Message: 1773 From: frank_19_88 Date: 9/5/2011
Subject: Re: PTT or TTL (Analogue or digital)
Hey,
I found a match cheaper one;
http://www.stappenmotor.nl/Datasheets/CNC%20lineare%20encoder/CNC%20lineare%20encoder.pdf
But it has only a A and B signal no - signals.
Can you give me the settings for those 3 options?
Thank you,
--- In DynoMotion@yahoogroups.com, "frank_19_88" <frank_19_88@...> wrote:
> Hi Tk,
> Frank
Group: DynoMotion Message: 1774 From: Tom Kerekes Date: 9/5/2011
Hi Frank,
You would want the digital encoder outputs not analog.  Differential signals (A+,A-,B+,B-) are preferred because they are less noise sensitive and can be connected right to Kanalog's screw terminals.   If you only have single ended signals (A,B) they can be connected directly to KFLOP (bypassing the differential to single ended receivers on Kanalog).  Unplug JP5 from Kanalog and feed the encoders into KFLOP there.  A terminating resistor to ground of around 150 ohms will help dampen signal ringing.  Another option is to use cable modules that convert single ended signals to differential signals.  I think USDigital and Digikey sell these for $10~15.
KFLOP's encoder inputs count at a maximum of 1.25 MHz.  Configure the Axis Channel as input type Encoder and set the InputChan0 setting for the encoder input that it is wired to.  JP5 has encoder inputs 4 through 7.
--- On Mon, 9/5/11, frank_19_88 <frank_19_88@...> wrote:
Subject: [DynoMotion] Re: PTT or TTL (Analogue or digital)
Date: Monday, September 5, 2011, 4:24 AM
Hey,
Thank you,
> Hi Tk,
> Frank
